- Ayuda para afinar OC a un i7 920
Resultados 1 al 25 de 25
Tema: Ayuda para afinar OC a un i7 920
21/06/2011, 14:56Usuario registradoLoLo2207
- 14 sep, 09
- Plasencia y Salamanca
Ahora que ha empezado el fresquete, me ha dado por hacer OC para no pasar frío :lol:
Actualmente lo tengo así, y por primera vez he conseguido hacer las 20 pasadas del LinX. El problema es que las temps suben a 85 grados en 1 o 2 cores y los otros 2 a 75 o así.
Así que me gustaría saber si:Código:> Advanced Frequency Settings [Press Enter] CPU Clock Ratio [20 X] CPU Frequency 4.00GHz (200x20) > Advanced CPU Core Features [Press Enter] Intel(R) Turbo Boost Tech. [Disabled] CPU Cores Enabled [All] CPU Multi-Threading [Enabled] CPU Enhanced Halt (C1E) [Disabled] C3/C6/C7 State Support [Disabled] CPU Thermal Monitor [Disabled] CPU EIST Function [Auto] Bi-Directional PROCHOT [Auto] QPI Clock Ratio [x36] QPI Link Speed 7.2GHz Uncore Clock Ratio [x16] Uncore Frequency 3200MHz >>>>> Standard Clock Control Base Clock(BCLK) Control [Enabled] BCLK Frequency(Mhz) [200] Extreme Memory Profile(X.M.P.) [Disabled] System Memory Multiplier (SPD) [ 8.0] Memory Frequency(Mhz) 1066 1600 PCI Express Frequency(Mhz) [100] >>>>> Advanced Clock Control CPU Clock Drive [700mV] PCI Express Clock Drive [700mV] CPU Clock Skew [ 0ps] IOH Clock Skew [ 0ps] > Advanced Memory Settings Extreme Memory Profile(X.M.P.) [Disabled] System Memory Multiplier (SPD) [ 8.0] Memory Frequency(Mhz) 1066 1600 Performance Enhance [Standard] DRAM Timing Selectable (SPD) [Auto] Profile DDR Voltage 1.5V Profile QPI Voltage 1.175V x Channel Interleaving 6 Auto x Rank Interleaving 4 Auto >>>>> Channel A > Channel A Timing Settings [Press Enter] > Channel A Turnaround Settings [Press Enter] >>>>> Channel B > Channel B Timing Settings [Press Enter] > Channel B Turnaround Settings [Press Enter] >>>>> Channel C > Channel C Timing Settings [Press Enter] > Channel C Turnaround Settings [Press Enter] > Advanced Memory Settings Voltage Types Normal Current ------------------------------------------- >>>CPU Load-Line Calibration [Level 2] CPU Vcore 1.22500V [1.30000] x Dynamic Vcore(DVID) +0.00000V Auto QPI/Vtt Voltage 1.175V [1.315V] CPU PLL 1.800V [1.800V] >>> MCH/ICH PCIE 1.500V [Auto] QPI PLL 1.100V [Auto] IOH Core 1.100V [Auto] ICH I/O 1.500V [Auto] ICH Core 1.100V [Auto] >>>DRAM DRAM Voltage 1.500 [1.640V] DRAM Termination 0.750 [Auto] Ch-A Data VRef. 0.750 [Auto] Ch-B Data VRef. 0.750 [Auto] Ch-C Data VRef. 0.750 [Auto] Ch-A Adrdress VRef. 0.750 [Auto] Ch-B Adrdress VRef. 0.750 [Auto] Ch-C Adrdress VRef. 0.750 [Auto] > Miscellaneous Sttings [Press Enter] Isochronous Support [Enabled] Virtualization Technology [Enabled]
- Tengo algún voltaje muy alto o debería cambiar algo
- Si al desactivar el HT notaré mucho el bajón o no de rendimiento, porque según he leído me bajarían unos 10º las temps.
- Qué opciones de ahorro de energía debería activar para que siga estable esto?
- Debería poner las latencias en manual?
Saludos y gracias.
Mi equipo:
Código:Intel Core i7 920 Gigabyte GA-x58-UD7 Mushkin Redline 6GB 1600MHz Noctua NH-D14 ATi HD5870 Corsair HX850 Coolermaster HAF 932
23/06/2011, 02:22Usuario registradoLoLo2207
- 14 sep, 09
Hola, alguien por ahí? :roll:
23/06/2011, 12:20Usuario registradotimyturnerxd
- 04 may, 11
mira no se desde cuando tienes ese procesador pero es lo peor
pero tienes que acerlo con nl2 o liquida
pero si esta bien
23/06/2011, 22:56Usuario registradoLoLo2207
- 14 sep, 09
Que me hace falta Nitrógeno Líquido???....
http://img96.imageshack.us/i/mentirameme.jpg/
25/06/2011, 20:10Usuario registradoN4T4L14
- 31 mar, 09
jajajaj
Iniciado por LoLo2207
25/06/2011, 20:11Usuario registrado CVDERFORE
- 16 sep, 08
No le hagas caso, seguramente este individuo durará poco en el foro, en principio no debería estar aquí, lo único que hace es molestar engañando a los usuarios y dando consejos sin tener ni idea de lo que habla.
25/06/2011, 20:15Usuario registrado CVDERFORE
- 16 sep, 08
Tú has visto muchas películas...
Iniciado por timyturnerxd
pero si esta bien
A lo mejor tu procesador es mejor pero es que no tienes ni pajolera idea de informática, así que por favor deja de crear confusión en el foro.
25/06/2011, 20:29Usuario registradoLoLo2207
- 14 sep, 09
Jajaja ya me lo suponía :lol:
Bueno pues volviendo al tema, si me pudieseis dar algun consejillo para mejorar el OC...
01/07/2011, 15:57Usuario registrado CVjosele1968
- 27 jun, 11
- barcelona
no esta mal el oc a lo mejor podrias afinar algun voltaje pero poco te cambiaria las temperaturas revisa la colocacion del disipador por que si es normal tener algun nucleo con mejor temperatua pero no es normal tener dos.
02/07/2011, 11:39Usuario registradosakmalister
- 11 may, 10
- Cadiz
Yo como poseedor de un 920, te puedo decir que llega con refrigeracion por aire a mas de 4.3 Ghz, el año pasado lo puse a esa velocidad en la campus y no podia subir mas por las memorias que me hacian tirar pantallazo azul.
Y las temperaturas... creo que eran unos 68 / 70 a full; con el voltage al tienes puesto al nucleo me parece increible que tengas esas temperaturas, yo lo pongo 1.28 / 1.3 y va perfecto, no se alomejor es la placa... o tu disipa :?
Lo que si te puedo afirmar que este procesador, aun siendo el mas bajo de su gama tira un monton y cuando empieza a subir de los 4Ghz hacia arriba, se vuelve loco y empieza a soltar su enorme potencial, yo me atreveria a decir que incluso podria hacerle frente al actual i7 960.
Espero que con este discurso tan pesado te haya animado a seguir probando con tu procesador, y llegar a nuevas fronteras.
Salu2!
02/07/2011, 17:44Usuario registrado CVPLAY911
- 30 nov, 07
por un casual tu placa base es Gigabyte?
02/07/2011, 17:51Usuario registradosakmalister
- 11 may, 10
- Cadiz
a quien preguntas PLAY911?
si es ami, es una: EVGA X58 SLI Classified 3
03/07/2011, 09:13Usuario registrado CVPLAY911
- 30 nov, 07
no, le preguntaba a LoLo2207.....
03/07/2011, 15:24Usuario registradosakmalister
- 11 may, 10
- Cadiz
Re: Ayuda para afinar OC a un i7 920
lee el post completo... :wink:
Mi equipo:
16/07/2011, 18:40Usuario registradoLoLo2207
- 14 sep, 09
Joder, creía que no había mas respuestas al post. No sé por qué ya no llega el aviso por email.
A la respuesta de arriba: sí. Por??
16/07/2011, 20:22Usuario registradoLoLo2207
- 14 sep, 09
Una duda, debería dejar el QPI/Vtt volt. en auto y ajustar el Vcore primero?? A ver si consigo unas temps decentes y un buen OC
16/07/2011, 22:14Usuario registrado CVjosele1968
- 27 jun, 11
- barcelona
intenta poner todos los voltajes y no dejes ninguno en auto. el vtt segun la veocidad de las memorias tendras que subir lo mas o menos
16/07/2011, 22:36Usuario registrado CVPLAY911
- 30 nov, 07
Lolo yo tengo un i7 930 con los siguientes valores (los he bajado un poco para que no sufra ahora que es verano)
He desactivado el HT por que como uso el pc para jugar los 8 hilos no hacen falta lo 4.2 con 1.296 en bios que son 1.267 con cpuz----
El voltaje el CPU PLL a 1.4 como suena y el default es 1.8 pero a mí me va de PM a 1.4
El PCIe´súbelo a 103 y su voltaje 1.520 V
Los demas les pones el default no los dejes en auto
El QPI voltaje a 1.335
Los
CPU Clock Drive a 700mV
PCI Express Clock Drive a 900mV
Y creo que cone esto te debería ir de PM
Suerte"!!!!
17/07/2011, 15:42Usuario registradoLoLo2207
- 14 sep, 09
Iniciado por PLAY911
Los
Suerte"!!!!
Tio, te quiero :oops: 20 pasadas en LinX con unas temperatuas máximas de 78-78-74-73. Además, con el HT desactivado, he tenido el mayor pico de Gflops xDD 58'8145 (antes unos 52'999 o así)
Ahora a ver si podemos bajar algún voltaje todavía mas xD
Edit: dejo capturas
http://bit.ly/onBUzG
http://yfrog.com/kg31834934p
http://yfrog.com/kji1cp
http://yfrog.com/kjyphp
(como podéis ver los timings se me han subido a 10-11-11-29 siendo las memorias de 6-8-6-24. Es malo?)
EDIT2: debería ponerle el trasto este --> http://i070.radikal.ru/1012/48/8e5248eec6a5t.jpg ??
17/07/2011, 18:05Usuario registrado CVPLAY911
- 30 nov, 07
De verdad que me algero que te vaya bien.....para 4.0 bajale el voltaje más te debería ir ok con 1.24 o lo mejor menos pero pruébalo hasta que te falle el lynx....el voltaje de la memoria ponlo a 1.58 o por ahí y bájale las latencias.....te rendirá más (aunque en los juegos no se nota mucho)
ahora que ya lo tienes "domado"....La otra opción que tienes es intentar alcanzar el 4.1 o 4.2 con 4 hilos que yo creo sí que puede
PD lo de los GFLOPS es mentira aunque te rinda más el linx con 4 que con 8 hilos es mentira, siempre rendirá más con 8....digamos que el linx no se enterá de los 8 hilos.
19/07/2011, 18:24Usuario registrado CVzuluneitor
- 24 oct, 10
- Badajoz
Tengo una rampage 2 Extreme y siguiendo guias y resultados de otros usuarios tengo un 920 a 3.8 con un NH-D14. Como es para juegos y el QPI lo tengo a 7,6, HT on, me interesaría saber cuando se que bajando los voltajes algo no va bien, por pantallazos azules?
19/07/2011, 18:46Usuario registrado CVRaymcoy
- 24 feb, 03
Pues bajas un poco le pasas prime y 3dmark, ke se cuelga pues ya sabes ke tas pasao keno se cuelga, pues sigue asta ke des con el v correcto
19/07/2011, 19:32Usuario registrado CVPLAY911
- 30 nov, 07
Zuluneitor postea tu confiración completa para que te podamos ayudar
19/07/2011, 19:54Usuario registrado CVzuluneitor
- 24 oct, 10
- Badajoz
Ahora me piro de vacas
, que estoy como loco...
En cuanto vuelva retomo el post os pongo datos y me comentais.
14/05/2012, 10:00Usuario registradomulo
- 26 feb, 05
yo también tengo un i7920 do y , aunque no le he pasado de 3800, se que es un micro de pelotas
